LandmarkMoving an object to a specific location
Command
Path
Move Geographic
Modify > Move
You can move an object in a georeferenced file to a different geographic location.
To move an object geographically:
Select the object to be moved.
Select the command.
The Move Geographic dialog box opens.
Parameter
Description
Move to location
Moves the selected object to the specified Latitude and Longitude
Latitude/Longitude
Specifies the latitude and longitude to which the object will be moved; enter decimal degrees, or degrees/minutes/seconds (for example, 39.18, 39° 10’ 32”, or 39d 10m 32s) preceded by a minus (-) sign when appropriate
Move relative
Moves the selected object from the current location using the specified Azimuth and Distance
Azimuth/Distance
Specifies the direction in degrees (0° is the Y axis, 90° is the X axis), and the distance the object will be moved, in document units
Specifying document georeferencing
